1998 Yamaha Big Bear 350
Old Nov 21, 2009 | 09:31 PM
sandrunners's Avatar
Default 1998 Yamaha Big Bear 350
My Dads Big Bear 350 will run for about 30 minutes then backfire and die, after it cools down it will start run for awhilethen do it again, any ideas?
Old Nov 22, 2009 | 02:41 AM
HeftyLefty's Avatar
Check carb and tank vent tubes. When dead, do you get spark from plug?. If no spark, change plug and check ignition circuit. If you get spark, check carb float bowl for fuel, carb float could be sticking or float fuel inlet clogged; causing float bowl to run dry.
Old Nov 22, 2009 | 04:04 PM
He has replaced coil,plug, spark plug wire checked all carburation . It seems to be a heat electrical thing. Maybe a faulty thermo switch?
Old Nov 23, 2009 | 07:12 AM
HeftyLefty's Avatar
Have stator and stator pickup tested, it could be overheating and shorting out. A competent motorcycle shop can probably test it for you, if your dealer can't.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Ean
Aug 28, 2015 09:39 AM
Peter_
Jul 18, 2015 07:06 AM
clsharky
Jul 13, 2015 02:07 PM
