2003 yamaha warrior 350 wont run
Old Dec 25, 2009 | 04:18 PM
dupont's Avatar
Default 2003 yamaha warrior 350 wont run
i dont know how to fix my worrior. Heres what happened,I was riding and it stalled, i started it again and it would run as long as i didnt give it and gas. so i was inspecting it and the carburator intake boot was craked. i thought when i was giving it gas it was getting to much air because of the boot . so i replaced it and now when it doesn't start unless i put my hand over the air intake on the carb . even then it runs a full rev and im nit giveing it gas.
Old Dec 26, 2009 | 04:24 PM
91Warrior357's Avatar
might still have a vacuum leak or the carb needs to be thoroughly cleaned
Old Dec 26, 2009 | 04:45 PM
dupont's Avatar
i cleaned the carb still didnt work then someone else told me to clean it so i did it a 2nd time still didnt work.
Old Dec 27, 2009 | 09:54 AM
Racingbrat's Avatar
Check to make sure your throttle cable is not hanging up , or make sure you put the slide in the right direction.
Old Dec 28, 2009 | 02:40 AM
draarong2004's Avatar
i'm gonna bet that when it stalled, it stalled because the parking brake lever came loose and the computer thought it was "on".....if thats the case you pulled your carb apart for nothing and that may still need to be messed with, also where's your choke at? if its pulled "out" that may be a problem as well, i doubt its running "full out"....if it is then the engine is about to destroy itself
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Ashley S
Jul 31, 2015 09:46 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
