2000 Big Bear 400 questions
Old Dec 30, 2009 | 09:23 PM
Jmo's Avatar
Jmo
Default 2000 Big Bear 400 questions
I just purchased a used Big Bear 400 and have a couple quick questions as I have never needed a atv until I moved to where I am now.
1. Are there any specific issues with this model that I need to be aware of?
2. The place I hunt is flooded timber and there are two unavoidable spots where the mud is up to your seat. These spots are only about four feet long so I manage to make it through (sometimes by my buddy pushing) but needless to say concerned about maintenance. What do I need to do if anything maintenance wise to make sure it stays in good shape.
Thanks in advance for your replies.
Old Jan 10, 2010 | 09:29 PM
pyro2themax's Avatar
i have a 05 BB and well if you going to be going deep i would recommend snorkeling it i run in water alot in Florida and it does great once you relocate every thing higher this will help not getting water in to the axels i have never really had water in them except when i fliped mine in to a water canal. other than that go with bigger tires mine had 25'' exicutioners and honestly it slower it down bc its such a small tire. the BB is geared so low that it can handle a fair amount of rubber on it.
Old Jan 11, 2010 | 10:51 AM
Jmo's Avatar
Jmo
Thanks for the reply. I put larger mudzillas on it and it is handling it much better now. It was previously snorkeled so it shouldnt be to difficult to do this. I am running into an issue now with MPEM 20 a fuse blowing when I turn the key on which says there is a short. I am about to ask this on the forum so if you know anything about this let me know. Thanks for the reply
Old Jan 11, 2010 | 08:11 PM
yea mine does the same thing its in the front end i blow the fuse allot when im in the water its caused buy water getting in to the 12v plug and causing a short. i got that to drain better and keep it closed when in water.
Ean
Dec 19, 2022 08:48 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
