moto 4 225 need help
Old Jan 12, 2010 | 03:33 PM
poopzilla's Avatar
ok so i got the oil filter and gasket kit. I took the cylinder to a shop and it will be $52 to have it bored so that will be geting done next weekend then all i have to do is get a piston. I found one on ebay that is 1.00mm oversized with a 71.00mm bore. I think my cylinder is 70.5 but we will see once i get it back from the shop.
p.s can i chang this thread name to (moto 4 225 rebiuld)
Old Jan 14, 2010 | 08:07 PM
danatack's Avatar
i'm still trying to figure out if i'm repling to the threads the right way. anyway sounds like your project is in good hands and my expeireance with piston and oversizeing, means the machine shop will match the cylinder to the piston. are you going to have the rod resized, or does anyone offer under/oversize bearings? as far as mods, call or visit on the web Duncan racing or CT, those guys would know whats available for a 225. i'm sure DG or FMF still offer a pipe and such. i'm currently ordering elka/lonestar suspension for my sons raptor 250. he wants to get into racing. keep me posted on your project, those moto-4s were great machines.
Old Jan 16, 2010 | 10:14 PM
poopzilla's Avatar
thax for the help. The cylinder should be going in the shop next weekend and i will keep you all updated.This is a slow project trying to get the funds up is hard to do with a low income at the molment so hang in there.
Old Jan 29, 2010 | 08:21 AM
poopzilla's Avatar
Just a little update. So when i got up monday i when into my garage to do a little work on the old moto 4 and found the the hole garage was flooded! and had to be pumped out it must of had 2" of water in there and had alot of cleaning to do but any way the cylinder is going out next week to be bored and i cleaned the head up and i thing it loos better then it did but still don't like the look of the exhaust valve.
Size:  22.3 KBName:  Image008.jpg
Old Jan 29, 2010 | 09:08 AM
  #15
TLC's Avatar
TLC
Isn,t the Moto 4 the same 229.6cc, 71 X 58mm BORE X STROKE and COMPRESSION RATIO 8.7:1
That they used in there 250 Bear trackers and Timberwolf and 250 Briun/Grizzlys now? I had a 87 moto4 and the sticker on the side said "250" not 225.
here is the Clymer maual for a moto4 and it covers 1987-2004 more because the book was printed in 2004.http://images.google.ca/imgres?imgur...a%3DN%26um%3D1
Old Jan 29, 2010 | 10:30 AM
  #16
poopzilla's Avatar
i don't think so but ii could be wrong this is my first atv project so im learning as i go. i think the stock 225 had (70x58mm and copression ratio 10.25:1 and with a displacment 223.6cc)but i was told my engine was rebilt befor and it had a 70.5mm bore so it was at 225cc. With the new bore and piston at 71mm should get 226cc a hole 1 cc more lol.
Old Jan 29, 2010 | 10:43 AM
  #17
TLC's Avatar
TLC
I guess the 229.6 they use now came out in 87 then.
Old Feb 1, 2010 | 01:01 AM
  #18
Malachi's Avatar
I've got an odd Yamaha called a Prohauler and it's actually considered a 230cc by Yamaha. Doing a little research on what will and won't work for a top end rebuild I've found alot of the Moto 4 (225), Beartracker, Timberwolf and Big bear (250) parts are interchangable.
Don't have the list on me at the moment, but if you'd like a copy PM me.
Old Feb 3, 2010 | 09:35 PM
  #19
danatack's Avatar
sorry to here about your garage, that vavle does look a bit corroded. you might be able to clean the surface rust with sand paper, but i'm worried more about the valve seat and face. since you already have the head off i would have the valves inspected. i have read those (kibble white) valves are good and they come with springs and retainers. ck out there site. anyway looks like your project is coming along. dont you love how other people tell you how to spend your money lol. just kiddin, it sounds like you got a cool project and it would be a bummer to put it together and not run right because of valve train problems.
Old Feb 8, 2010 | 04:08 PM
  #20
poopzilla's Avatar
ya valve problume would suck after geting it all back together. Dose any one know of any one that might sell a kit for it or am i going to have to order the part seprit?
