Head gasket or Cracked Block ?
Old Jan 4, 2010 | 05:54 PM
faponce's Avatar
Default Head gasket or Cracked Block ?
I have a Grizzly 660 and it's getting water in the oil. It runs fine doesn’t misfire or blow any smoke of any kind. I would think if it was a head gasket it would pour white smoke.
My son was driving when it started getting hot so I'm not sure exactly what happened but it started getting hot and when I checked the coolant it was low. I refilled it and 30 min later it was low again that's when I checked the oil and found chocolate milk.
Any suggestions would be appreciated.
Old Jan 4, 2010 | 06:09 PM
wheily's Avatar
unfortanitly the only way to realy know would be to pull the head .i have had head gaskets go on my moter bike and only new it when it started spewin out the crankcase never smoked just felt a little sluggish but still ran good
Old Jan 4, 2010 | 08:17 PM
danatack's Avatar
yes coolant in the oil is simpely a bad thing. you can put your mechanic suit and hat on and perform compression, leak down, dye in the system and so on tests... or prepare for surgery and remove and inspect the head and gasket. you'll probably find a trace or witness mark where the coolant was cross leaking, with piston at bottom dead center you can inspect the cylinder for a hair line crack, or transport machine to a machine shop and ask them to "magnaflux" the cylinder and head. (old procedure for crack detection). hopefully you can see the problem right away i hate chashing ghosts. i believe that power plant has a steel cylinder sleeve and not a cermamic one like the raptor 250.
Old Jan 4, 2010 | 10:23 PM
faponce's Avatar
Thanks for the info I'll pull the head and hope for the best.
Old Jan 4, 2010 | 11:50 PM
Doctorturbo's Avatar
GOT BOOST!
Of all the time on this forum I don't recall one cracked jug. I don't have enough fingers and toes to count the head gasket problems I have seen. (I won't say it does not happen but..........)
Does that make you feel any better?
Old Jan 6, 2010 | 02:13 PM
geoman's Avatar
I have never heard of a cracked jug or head on a single cylinder either. I am betting the head gasket also.
Old Jan 6, 2010 | 02:15 PM
geoman's Avatar
That all depends on where the head gasket is leaking at...
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
