Grizzly 700 brake problem??
Old Jan 4, 2010 | 06:11 PM
rtboy's Avatar
Default Grizzly 700 brake problem??
I have a 2007 grizzly 700 and when I first got it the front brakes would lock up like abs. When I grab them normal they lock up . The front brakes would never lock up when I pull the lever slow it does not slow the quad down easy. Right now I have 2000 miles on it and all I use are the back brakes. Is this normal for grizzly 700s?
Old Jan 4, 2010 | 06:25 PM
HeftyLefty's Avatar
Check front pads for dirt and wear. Caliper piston may be seized as well.
Old Jan 4, 2010 | 06:28 PM
rtboy's Avatar
I will check it. It has done this since I first got the grizz
DODGE57HEMI's Avatar
Mopar Man!
This is deff not normal and a problem and one I have never herd of on a Grizz. My guess is you have a front master cylinder malfunctioning. You can check with the guys at http://www.grizzlycentral.com/ if you want a second opinion. Good luck let us know what you find.
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
toonces
Jul 11, 2015 12:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
steveo612
Jul 11, 2015 08:35 AM
