Common Banshee Problems
Old Feb 25, 2001 | 10:31 PM
ytztriz's Avatar
Can you guys tell me what are common Banshee problems that you deal with. With the engine,chassis, or just stupid maintence you have to always have to do to it before and after riding things like that
Old Feb 25, 2001 | 11:46 PM
Holyman's Avatar
The chain tightener is totally retarded, the frames twist when you roll 'em and the upper "A" arms are weak.
Other than that they're great.
Oh yeah the air filter is a joke too.
Old Feb 26, 2001 | 01:49 AM
Trxoutlawz's Avatar
These are the things that I have done because I thought they needed improvement....
TORS... Removed + added twist throttle
Air box.. Removed, open air filters /outerwears.
Pipes.... Toomey T5's Chromed
Crank... True and Welded
Cylinders.. Ported and Polished by Dennis Packard
SwingArm.. +6 Chromed/Honda style carrier
Water pump..New billet pump and custom inline cooler
Head.... New cool head with 18cc domes
Regular maintenance and all is well....
Old Feb 26, 2001 | 02:58 PM
raptor826's Avatar
chain adjusters and rear end come loose after a long ride. use lock-tite, AMP link helps, may need to modify axle carrier. water pump does not hold up, buy an aluminum one. clutch heavy, buy easy clutch kit/lever. put a gas filter on bike. carbs are a pain to take out and put back in.
Old Feb 26, 2001 | 11:03 PM
Zorro's Avatar
Problem #1. The one you MUST change as soon as possible is the air filter. Get a K&N or Foam (your preference), but for no reason keep the stock one. It will eat dirt. I found mud/dirt in my carbs after every ride until I changed to a K&N. Haven't had problems with it yet (PS: with a K&N, don't waste your money in a proflow, you can get the same results with a simple K&N -which is 1/2 price- and 1minute of "work").
Problem #2...?
Improvements : endless, but here are some favourites:
pipes, tires, billet kick starter and shifter (uless you enjioy a funny rattling noise)...etc
Old Feb 27, 2001 | 11:37 AM
moe4's Avatar
Banshee's love those plugs!! I go through them like water and I'm as lean as I can go!! Stock air filter sucks and the chain adj. is whacked. The usual crap.
Old Feb 27, 2001 | 02:56 PM
AZRENEGADE's Avatar
The only "common" problem that I am aware of is the air filter setup. There are 3 Banshees in my family a 94, 95 and a 97. Based on my experiences, these quads are close to bullet proof under normal conditions. One of my brothers-in-law (95 Banshee) literally performs NO regular periodic maintenance to his Banshee and has had no problems at all and only just recently redid his top end. I discount my other brother-in-law and myself because we are into our Banshees and are very careful about routine maintenance. In my opinion the Banshee is a great quad and one hell of a ride!
Old Feb 27, 2001 | 03:15 PM
RoostKing's Avatar
I have to disagree with Zorro. You MUST go to a pro-flow if you want to keep your motor together for a good long time. You will not get the same results from a "jerry rigged" stock air cage. I have seen a dyno chart that shows a Banshee equipped with the Pro Flow and K&N pick up almost 5 horsepower over the stock setup. Trust me, you want to pro flow... The plastic simply will not pass the air as smoothly as the pro flow...
RoostKing...
Cole Hadden
Jun 15, 2025 09:05 AM
JoAnnS
Jul 23, 2015 02:18 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
