2001 raptor 660 using oil. need help!
Old Jan 25, 2010 | 12:27 PM
punisher83's Avatar
Exclamation 2001 raptor 660 using oil. need help!
i have a 2001 raptor 660r. i noticed that it has been losing some oil, like a quart in 15 min! I checked the whole thing over for leaks or drips and i couldnt find anything at all. When i ride i also dont see any blue smoke what so ever when im driving it so i dont know where it could be going. the only time i notice a little bit of blue smoke is when it starts up cold. this only lasts for about 5 min then the smoke is gone. any ideas???
Old Jan 25, 2010 | 07:30 PM
punisher83's Avatar
it seems turn burn the oil mostly when i punch it alot. it will go through a quart in like 15 min then i will add it and it seems to be fine. this happens quite a bit. any ideas?????
Old Jan 28, 2010 | 10:54 PM
Raptor450's Avatar
Wow, a quart in 15 min???? If it's blowing blue smoke, then thats a sign of buring oil, but I've never seen any machine burn that much oil that fast. Probably just time for a rebuild on the top end.
Old Feb 5, 2010 | 02:10 PM
garyc660R's Avatar
Calm down.....did you just change oil and the oil level go down upon startup? Normal.
Old Feb 6, 2010 | 11:00 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
this.
or check your air filter box... you might be in for a surprise.
Old Feb 7, 2010 | 10:10 PM
punisher83's Avatar
yeah i checked over everything. and i did not change the oil in it yet. i checked the plug and its a light brown color with no signs of oil. i need to add some oil about every half hour and it seems to not be as bad but i still gotta add about 1/4 a quart each time. so i have no clue what to look for. and i looked for leaks and nothing seems to be leaking.
Old Feb 7, 2010 | 10:12 PM
punisher83's Avatar
and there is no blue smoke, only upon startup then it goes away once its warm
Old Feb 8, 2010 | 05:43 AM
08 rap's Avatar
Raptor-Central - Index check these guys out we got a couple of damn good raptor mechanics on here that can help ya out,ask for scott or dan
bmxatv10
Oct 14, 2022 06:23 PM
35dodge
Sep 29, 2015 09:40 AM
black_thunder
Sep 22, 2015 07:59 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Alex Rodak
Sep 12, 2015 09:39 AM
