Bear Tracker 250
Old Feb 18, 2010 | 12:26 PM
GodsCountry's Avatar
Default Bear Tracker 250
OK, so I added some seafoam to the fuel tank and the machine seems to be running better. At 10 below zero I can pull the choke all the way way out at it starts right up. The choke seems to have 2 different levels. First thing I do when atv is cold is I pull the choke all the way out. After it warms up I press the choke in until the first click. After some riding I try and push the choke all the way in and it starts to sputter like it is starving for gas. At this point if I pull the choke out just a little it runs fine again.
Why does it sputter when the choke is pushed all the way in? I mean I can just barly pull in out and it will run fine...
Thanks
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
