Help... 2006 Raptor 700 DEAD!
Old Feb 18, 2010 | 05:44 PM
DETROITBOMB's Avatar
Thumbs up Help... 2006 Raptor 700 DEAD!
I attempted to start my quad today and it is DEAD. I live in Michigan (cold) so I have a battery tender hooked up. I have power, headlights (bright) and my nutural lights up on "dash". Any ideas where I should start to fix this problem??? Please help. Its been a few months since I last started the quad. Thanks
Old Feb 18, 2010 | 09:18 PM
Kevin R.'s Avatar
Hook a volt meter up to the solinold and see if you have voltage on the Batt side. If not then a fuse may be blown. Then check the starter side and see if you are getting voltage when you are hitting the start switch. If not then see if you get a start signal from the starter button. if yes, you may have a bad solinold, if not you need to trace the circuit up to the start switch and look for bad wires and grounds.
Old Feb 19, 2010 | 08:17 PM
Thanks for the info Kevin. I will try it out.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
