Warrior Gearing
Old Mar 15, 2010 | 09:18 PM
WarriorRider0277's Avatar
Question Warrior Gearing
I just recently rebuilt my top end on my 97 warrior. I also bought a new axle, sprockets, and chain. I bought a 13/40 stock gearing kit, but unfortunately I forgot about the 20x11-9 holeshots that are on it. The old front sprocket was a 15t, and I was wondering would it be ok if i did 15/40 with my tires being the way the are? or should I keep the 13/40? Im shooting for close to stock, and I heard that if your front sprocket is undersized you may lose speed. Any and all help appreciated.
Old Mar 15, 2010 | 10:08 PM
91Warrior357's Avatar
mines the same 20 inch razrs and stock ratio, i kinda wish i went higher, i fly through gears like a hopped up banshee, but then again all i do is ride in XC terrain so thats why i kept it stock ratio, 15 is pretty steep for a warrior unless you got a couple mods, but i guess it depends on what terrain you ride in, the 13t should make you a tad below stock and the 15 would be a little above stock, a 14 would prolly put you close to stock top speed on a warrior which is like 58 i think...
Old Mar 15, 2010 | 10:10 PM
beastlywarrior228's Avatar
13 is stock but 14 might've been the way to go. a 15 would be waaaay to much acceleration would be horrible
Old Mar 15, 2010 | 10:26 PM
but wouldnt itusing the 15 tooth sprocket now with smaller tires be the same as using a 14 tooth sprocket with stock tires???
Old Mar 16, 2010 | 09:55 AM
no 14 is the max for 20 and 22's i dont think a 15 would be good for 18's
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
