01 warrior sputtering
Old Mar 26, 2010 | 10:21 PM
vikings68's Avatar
Even with the mods you recommend a 150ish jet? You think it is getting too much fuel?
Old Mar 27, 2010 | 05:02 AM
Simtech's Avatar
Do one more test. Ride it and when it starts to sputter pull the choke. If it clears up then it is too lean. If it dies then it is good, if before when you pulled the plug after a sputter it was not soaking wet. I beleive this will rule out the fuel issue. However those are some pretty big jets. Where those recommended by a shop?
Old Mar 27, 2010 | 02:36 PM
beastlywarrior228's Avatar
ya im runnin a 148
Old Mar 27, 2010 | 02:43 PM
91Warrior357's Avatar
yea its really uncommon to see people running higher then 152's mine ran a 148, im using dynojets now and there scale is a little different.
Old Mar 28, 2010 | 12:45 PM
  #15
vikings68's Avatar
Pulled choke out when it started sputtering-fell on its face,that resolved replaced 180 jet with 154 and the bike runs even worse wont even pull past half throttle before it starts sputtering. Thx
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
