Parking Brake Removal
Old Mar 1, 2001 | 12:38 AM
ewilmarth's Avatar
Has anyone done this and have a good clutch lever and perch to recommend. I know the block off is the same as Banshee. Also what did you do with the clutch and parking brake electrical interlock switches?
I would appreciate any help!
Thanks, EW
Old Mar 1, 2001 | 06:00 PM
Qracer31's Avatar
pepe makes a good lever, its adjustable from regular pull to 30% easier pull
Old Mar 1, 2001 | 06:25 PM
redrocker's Avatar
I have a yz426 setup on mine
take a look at one they have avery
nice adjustment on them
Old Mar 1, 2001 | 08:22 PM
Zorro's Avatar
I just did it yesterday!! Made the block off plate myself (doesn't look as nice as Cascade's...but free and no waiting for it).
I installed a Raptor MSR clutch lever/perch. I got it 60$cdn...and it works great, really precise, adjustment is instantaneous...real great. For the stock gumby, I just unplugged everything...but I have nomore TORS and the 3 wire autokill under the tank is unplugged...so maybe that's why I have no problem.
Old Mar 2, 2001 | 07:33 AM
Mudrat454's Avatar
On the Raptor you just unplug the white connector and leave it unhooked and there are two green colored quick disconnects that you unplug and plug the two from the machine back together It works great. I filled the white connector with dielectric grease and then covered it with silicone so I could use it again if I had to.
toonces
Aug 5, 2015 05:55 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
