1998 Yamaha Timberwolf Maintenance
Old May 1, 2010 | 09:19 PM
jpr6436's Avatar
Default 1998 Yamaha Timberwolf Maintenance
The bike was running before it sat up for the past 2 years. I am going to change to the oils in the bike and definately drain the gas. I was wondering if there was anything else I should give a look at before I give it a crank? Thanks.
Old May 1, 2010 | 09:57 PM
91Warrior357's Avatar
plug, oil, oil filter, air filter check, airbox check(bird nest,bee hive,mouse nest,leaves), drain old gas and fill with new gas, run an engine cleaner like seafoam through it would help, clean the carb if you can.
Old May 2, 2010 | 03:45 PM
jpr6436's Avatar
Thanks for the help, I will do that.
2quiker
Mar 22, 2022 08:36 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
mrmickman123
Aug 30, 2015 10:37 PM
honda71
Jul 12, 2015 05:56 AM
