R300st
Old Jun 11, 2010 | 12:20 AM
james962's Avatar
Default R300st
Engine R300ST
APPROVAL:EEC
Engine Type:Single Cylinder, 4 Stroke, Liquid Cooling, OHC, Automatic(CVT)
BorexStroke:71x66.8 mm
Compression Ratio:10.5:1
Displacement:264.0 cc
Max Power:12.7 kw/(7000±5%) rpm
Max.Torque:21 N.m/(4500±5%) rpm
Fuel Tank Capacity:12 L
Gear:2 Forward Gears And 1 Reverse Gear
Transmission Mode:Shaft(4X4)
Start Mode:Electric
Max.Speed:72 km/h
Ignition Mode:CDI
Battery Capacity:12 v14Ah
Engine Oil:1.5 L
Lubrication:Press Splash
Parking Trig:Mechanic Lock
Chassis
Min.Ground Clearance:295 mm
Front Tires:AT25x8-12
Rear Tires:AT25x10-12
Front Brakeisk
Bear Brakeisk
Front Suspension:Independent Double Swing Arm
Rear Suspension:Independent Double Swing Arm
Product Dimensions:1865x1170x1211 mm
Wheelbase:1180 mm
Seat Height:910 mm
Dry Weight:300 Kg
Load Capacity:165 kg
Climbing Ability:bigger than 25 degree
Min.Turning Radius:3100±200 mm
Max.Number of Riders:1
Others
Color: Red, Blue, Green
QTY of 20'/40'/40HQ' container: 10/20/30 units
