Warrior not ran for 4 years
Old Aug 23, 2010 | 09:05 PM
mousty's Avatar
Default Warrior not ran for 4 years
I have acquired a 91 Yamaha Warrior. said the motor was proffesionally rebuilt and had only ran 1 tank of gas through. The quad was running when it was parked. what should I check or do to get running right away after setting that long? Thanks In advance. Mark
Old Aug 24, 2010 | 11:59 AM
91Warrior357's Avatar
drain all the old oil and gas out, and add new premium gas in it, new JASO approved oil and a new oil filter, clean the airfilter or replace if you have to, make sure everything is greased, you might have to take the carb off and clean it also, sitting that long most likely it has tarnish built up in the carb, check the battery and see if you can get it working by checking the electrolyte level and adding distilled water untill its at the right level and charging it, if not the just buy a new one.
Old Aug 24, 2010 | 07:30 PM
mousty's Avatar
Got it running but It bogs when you hit the throttle and gas leaks out of the carb(2 side hoses) Is the float stuck or just more junk in the carb?
Old Aug 24, 2010 | 10:09 PM
dirtydave4's Avatar
check the breather hose to carbi is not blocked , could have got wasp or something blocking it
Old Aug 24, 2010 | 10:27 PM
mousty's Avatar
where is that located? is that the large hose by Air cleaner?
Old Aug 24, 2010 | 10:34 PM
dirtydave4's Avatar
there should be a small brass tube on carbi its self , it should connect to breather hose runnig up the frame
Old Aug 24, 2010 | 10:37 PM
mousty's Avatar
Ok if it is on the bottom there is no hose atatched to it. Also have 2 small hoses coming down both sides. all 3 had gas running out of them at first. now gas comes out when I give if full throttle and it bogs?
Old Aug 24, 2010 | 10:54 PM
dirtydave4's Avatar
sounds like your float is sticking then
Old Aug 24, 2010 | 10:58 PM
mousty's Avatar
do I have to remove whole carb or can I just take off the bottom section? And Thanks So much for your replies!!!!!
GtownRider's Avatar
Could be lean mixture, clean the carb and check again. May need to adjust mixture screw if it isn't all varnished/blocked
