Warrior Head Pipe
Old Mar 5, 2001 | 09:48 PM
fourjs's Avatar
I'm going to replace my pipe with either a FMF Performance or White Brothers E-series, which one is best or they about the same? Also, do you need to replace the head pipe on the warrior, since it is already on the big side, would it be to any advantage to replace or use a slip on????
Old Mar 5, 2001 | 10:25 PM
motomatt15's Avatar
i was looking at both of those pipes for my warrior and i decided to get the e-series.the fmf is a good pipe but i like the e-series better.
Old Mar 6, 2001 | 03:04 AM
loweredbowtie's Avatar
I like the sound, looks, and performance of my e-series. As far as power goes I believe the fmf is about the same thing. When I looked for a header I couldn't ever find one, but as big as it is stock I don't think a bigger one one help, it may cause too much airflow, which would result in a warped or burnt valve.
Old Mar 8, 2001 | 03:15 PM
henz08's Avatar
i have a FMF on my 97 warrior and i like it a lot. Performance wise i believe they are about the same. You do not have to replace the head pipe but if you do i believe it is to your advantage. You can find FMF head pipes at fmfracing.com. They have 2: the powerbomb header and the high flow header pies.
Old Mar 8, 2001 | 06:04 PM
fourjs's Avatar
Did you notice any major gains after installing your pipe, and did you replace the head pipe or use a slip on??
Old Mar 8, 2001 | 08:16 PM
1BadWarrior's Avatar
I have a White Brothers E-Series exhaust on my 99 Warrior and I like it. It does pretty good and it does add a little extra power throughout the powerband. But with a K&N air filter,150 main jet & 45 pilot jet I could really tell a difference. My Warrior can now pull a wheelie in second gear.
Old Mar 8, 2001 | 09:48 PM
dawarriorman's Avatar
you can only pull a wheelie in 2nd gear now? I could pull one in second gear bone stock, and with what ive done now, i can get it up in third. Oh well.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
ltzbrad
Sep 25, 2015 05:52 PM
bvolks
Sep 13, 2015 12:57 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
