How to check timing
Old Oct 14, 2010 | 10:27 PM
miassmaro98's Avatar
Default How to check timing
Hey guys im having trouble with my wolverine 450 not running,so how do i check timing?
Old Oct 17, 2010 | 07:42 AM
any1
Old Oct 17, 2010 | 10:55 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Okay Take cam sprocket cover off,take inspection cap out of left engine cover turn engine over with wrench until T mark is inside of inspection hole ,then make sure the piston and cam is TDC ,you have marking on sprocket and head casting and make sure to match up. if the marks are off then loosen chain tensioner or remove tensioner assy., and rotate chain off sprocket to the correct location, now this is for machanical timing ONLY not ignition timing...What do you need?
Old Oct 17, 2010 | 02:16 PM
thanks,so how will i check the ignition timing?
Old Oct 21, 2010 | 03:31 PM
Really confused right now,took apart my wolvy turn the crank over till the t line up with the inspection hole.remove sprocket cover and sprocket mark is way off from the head mark but wait with the crank mark line up with the inspection hole the piston is not at tdc??????????but when i spin the engine over and line up the sprocket mark to the head my piston is at tdc but my crank mark t is nowhere to be found.what do i do next?????????????
Old Oct 22, 2010 | 08:18 PM
Loved
Community Favorite
Okay make sure you piston is tdc, then make sure your camshaft is tdc? When you know both are tdc then only then!!!! loose tenisionor,then take cam sprocket bolt out and rotate chain off the sprocket until the sprocket is lined up with marks.If you are uncomable doing this get an manual.... If you are okay than thats fine! Your next problem is why is it out of time? Did it jump time? or did someone put out of time? Did bend values?....
Old Oct 22, 2010 | 09:55 PM
my flywheel or rotor like its called is off,i think the crankshaft key way broke and the rotor moved and that is why my bike wont run because it spark's when its not suppose to.so i have to go buy some tools to remove the rotor and inspect the crank key
SOLOLUCKY
Oct 4, 2024 09:09 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
