2 inch lift for wolverine 350
Old Oct 20, 2010 | 03:54 PM
Hotrodbanshee's Avatar
Default 2 inch lift for wolverine 350
Anyone running a 2" lift on a wolverine 350? Was thinking about going with a cfm lift for mine. Is this a good choice? Any problems running these lifts?
Old Oct 21, 2010 | 12:10 PM
95wolv's Avatar
Are you trying to fit much bigger tires that you need 2"? Just remember with that much more lift, the angles on the CV axles will be much sharper, and if you run bigger tires to boot, they will wear out a lot faster than stock. I run 25" on my stock suspension Wolverine, and have not had any rubbing or clearance problems, and have rode it hard and jumped it a lot.
Old Oct 21, 2010 | 09:56 PM
I put 25" bearclaws on. No rubbing, but just wanted to do it for looks. Think I will just leave it alone, don't want to spend money on ball joints or cv joints.
QuadRiders
Oct 22, 2015 04:13 PM
Honski250r
Sep 26, 2015 09:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
lancemll88
Sep 6, 2015 03:03 AM
