Banshee build up
Old Dec 6, 2010 | 01:47 PM
colddogcat's Avatar
Default Banshee build up
Need Help please: I've got a 05 Banshee and i want to fix it up Right. I got T-5's and silencers, V- force 3 reeds, jets and airbox supplied with the pipes, boost bottle, and Razr 2s all around.
I'm wanting some low end power. Been looking at COOL Heads and such but I dont know what im looking for. Got money to spend and dont want to get beat on my Shee, so let me know, appreciate it.
Old Dec 6, 2010 | 07:12 PM
sdm111's Avatar
2 strokes or 4
The words lowend and Banshee contradict each other.
Old Dec 7, 2010 | 07:35 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Ha, ya banshee's are all or nothing. If it were me, I'd stay right where your at.
Old Dec 7, 2010 | 08:48 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Get it ported from someone that knows thier stuff. Check "BansheeHQ"
Old Dec 7, 2010 | 09:00 AM
colddogcat's Avatar
How should i go with sprocket size, and whats a good clutch
Old Dec 7, 2010 | 12:13 PM
desert.rat35's Avatar
if you are doing anything suspension related check out the ishock website
Old Dec 7, 2010 | 12:15 PM
colddogcat's Avatar
Will do..Thanks
Old Dec 7, 2010 | 05:31 PM
sdm111's Avatar
2 strokes or 4
Go down one on the front, but you'll lose topend might not be bad though worth a shot
Old Dec 8, 2010 | 11:18 PM
sand addict's Avatar
Banshee is known for top end power,you will get more low end power and torque if u add compression.cool head is a good idea,22cc domes is close to stock compression,at about 138 psi.20cc domes work well on pump gas,at about 155-160psi.also a timing advance plate with an additional 5 degrees of base timing.
Old Dec 10, 2010 | 12:11 PM
garyc660R's Avatar
Correct. Wrong atv to ask much low end power from. Upping compression helps some. Save money over the cool head and just have it shaved by a knowledgeable shop.
