2005 4x4 Wolverine Carb Problem
Old Dec 19, 2010 | 10:19 AM
Rutrider's Avatar
Default 2005 4x4 Wolverine Carb Problem
I am having problems with starting and idling in cold weather. I cleaned carb and it helped a little, but still doesn't right. i replaced the needle, seat, some jets and gaskets.
Does anyone know what other carbs will fit this atv?
Old Dec 20, 2010 | 09:48 PM
Butch450's Avatar
Did you actually adjust your fuel/air screw or Idle adjustment screw? I know I have to adjust my Idle screw as soon as the temps dip below 40.
Old Dec 22, 2010 | 02:32 AM
PSnewbie's Avatar
I've gone through 2 winters and haven't had to mess with anything on my carb, now my jetting is higher which would work with colder/denser air, but how much of a difference that it makes i don't know.
Old Dec 23, 2010 | 06:25 PM
rdeeno's Avatar
Of the jets you replace, was one of them the idle jet? Also, if the quad sits up for fairly long periods of time, I have seen idle jets get plugged up. My 125 Grizz is bad about doing that. They will generally crank and run with the choke on, but as soon as you turn the choke off, they die.
Old Dec 23, 2010 | 07:55 PM
PSnewbie's Avatar
No, my idle jet and needle are stock. I just upped the main jet by 10-15. I don't remember which right now. In the really, really, cold weather i just pull the choke all the way out, start it, and slowly lower the choke as the motor warms up. once she's warm she runs as if it was a summer day.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 20, 2015 01:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
