2002 grizzly 660 running rich
Old Feb 15, 2011 | 10:26 PM
bf650i's Avatar
Default 2002 grizzly 660 running rich
I just recently acquired a 2002 660. it apparently had the carb all rebuilt but runs extremely rich put a new plug in and is completely black. wont accelerate just boggs, have completely disassembled the carb and cleaned, main jet is a 153.8 and pilot is 55 does this seem right? Any help would be greatly appreciated.
Old Feb 15, 2011 | 11:40 PM
PAGrizz550's Avatar
Where are you located at? Whats the altitude in your area? Did you purchase this quad locally? Any other mods,air filter/intake,exhaust? Need some more info.Just a quick idea, could be bad gas the fule quality these days is junk try draining the gas in the tank and replacing it with new/fresh fuel.
Old Feb 16, 2011 | 11:04 PM
bf650i's Avatar
I am located in alberta. I have already drained all fuel,flushed the fuel tank. That was my first thought as well. I am at 2200ft of elevation. This machine has been running the same since it was apparently tuned up this last summer. Apparently all new jets. No other mods to quad at all. Was purchased locally.
Old Feb 20, 2011 | 12:06 PM
Kerbbirds's Avatar
air filter clean? did you check the crankcase for gas in oil? alot of times the needle and seat go bad and gas will fill the airbox and crankcase , causing very rich condition, pull the dipstick and smell it to see if it smells like gas, is oil over full? whats the air screw set at its on the bottom of carb, should be 2 to 2.5 turns out, may still have a brass plug over it if so you can drill plug and screw a sheet metal screw in it and remove with vice grips
RticKwad
12
Jul 19, 2015 12:22 AM
AtvManiac78
Jul 11, 2015 03:20 AM
Bm400ex
Jun 22, 2015 09:16 AM
robj
Jun 15, 2015 08:45 PM
Chawness
Apr 21, 2000 08:14 AM
