1987 yamaha warrior 350
Old Feb 19, 2011 | 03:20 PM
gatoreng1's Avatar
Default 1987 yamaha warrior 350
Replaced the timing chain, guide rails, top sprocket, and come to find out the tensioner does not touch the back guide rail.
Is it possible the top timing gear is not the right one? Has anybody ran into this problem. The quad runs, but the chain is obviously a little loose.
Old Feb 19, 2011 | 04:16 PM
Scooter86's Avatar
Knows Old ATV Questions!
More likely the tensioner needs replacing. These do wear out over time.
Old Feb 19, 2011 | 07:40 PM
gatoreng1's Avatar
To add to the post, the tensioner does not touch the guide rail, when it is installed in its fully extended condition.
1. Is it possible to have the wrong 32 tooth top sprocket?
2. Is the rail supposed to have an extended surface for the tensioner to hit?
3. I got a new timing chain that should be for the '87 as it is the same at least through '94.
4. Could the head have been shaved down? (I did get the bike used and it was not running.)
Any other solutions would be beneficial.
2quiker
Mar 22, 2022 08:36 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
Steeldon
Sep 8, 2015 10:51 AM
