ATV Coolant
Old May 19, 2011 | 12:43 AM
RDub's Avatar
Default ATV Coolant
Hiya
I'm a little hesitant to go out and get just any 'coolant' for my quads. Just what is ok and what is not. I know that coolant has to be aluminum friendly, but a lot of coolant products 'say' they are ok for aluminum.
So is there anything that is widely used in ATV's?
Thanks
Old May 19, 2011 | 11:29 AM
Doctorturbo's Avatar
GOT BOOST!
Green EG is what I see in quads. Regular old Prestone will work fine.
You can use PG too if you want but why? No advantage unless you blow a hose and your cat licks up the EG and dies.
What ever you do DO NOT mix the two. I have seen what happens and it's not good.
Some on here have fancy stuff like Enans and whatever. There is a lot of drawbacks to a lot of this fance stuff.
IMHO just put so Prestone in it and go ride.
Old May 19, 2011 | 06:36 PM
RDub's Avatar
Ok.. Thanks
Old Jun 2, 2011 | 08:33 PM
lightninboy's Avatar
Use a premix so you don't have to mix antifreeze and water in such small quantities and make sure it says it is good for all engines. I used some heavy-duty Fleetguard premix because that's what I have on hand.
Alex G.
Sep 11, 2017 11:38 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
