99 Big Bear 350 4x4 Issues,... "Please" Help!!!!
Old Dec 26, 2011 | 09:09 AM
stitchit1's Avatar
Default 99 Big Bear 350 4x4 Issues,... "Please" Help!!!!
I have a owned a 99 Big Bear 350 4x4 since I bought it new. Overall, alot of issues that I have learned to "deal with".
However, this particular issue has me dead in the water:
I have a broken part on the shifting assembly and I'm not sure what it is called, and how much is involved in replacing it. I have, till now, taken the atv to the dealer for repairs, but simply can't afford to so anymore.
Here are the pictures of the broken part:
From, of course, this part of the shifting assembly:
I have a good idea what caused it, and am not sure what to do to fix it: The atv runs only with the choke in the fully closed, (all the way out), position. After I ride it for a LONG time, about 25 minutes, it "might" idle with the choke not on, but normally will not unless fully choked.
So, because of this, I end up having the rpm's thru the sky, in order to keep it running. Needless to say, upon shifting, with the idle so high, I have to "REALLY" pull "HARD" on the shifter lever. Or, if I can "time it rite", I can put the choke in real fast, shift, and then pull choke back out to make the atv run.
I would greatly appreciate any help you might be able to give me, and can't wait to get this on the trails again!!!
P.S. Is there a "legitemate" online downloadable manual for this atv? Whats a good price to pay for one?
Thanks,
chris
Old Dec 26, 2011 | 10:10 AM
vangasman's Avatar
That is called a heim joint and should be available from the dealer fairly cheap. Your main problem sounds like you need to rebuild the carb. Kits are cheap and you can find a manual on cd rom for 9.95 on ebay.
Good luck, John
Old Dec 26, 2011 | 11:29 AM
stitchit1's Avatar
Thanks so Much!! Can you please give me a name of a reputable company to download the manual from?
Thanks,
Chris
Old Dec 26, 2011 | 08:33 PM
vangasman's Avatar
Don't know about any downloadable ones, these are on cd-rom, just stick them in your computer or you can save them on your computer so you don't have to run the disc every time. If you don't e- bay it's a good time to start!
Old Dec 29, 2011 | 07:50 AM
stitchit1's Avatar
Thanks again vangasman! I'm hoping you might be able to help me with another issue:
The "clutch" handle, (at least that's what I think it is), cable and actual handle has somehow managed to seperate. The pictures below show the current state of it, and I am not sure what/if any parts might be needed, or if it's an adjustment thing?
The handle just doesn't seem to come back to the position it should. It's almost like the thing has a broken spring or something.
I am still looking to find a site to order the part for the Heim Joint from, and will order this at the same time.
Is Ebay a good place to go for parts as well?
Thanks so much for your time!
Chris
Old Dec 29, 2011 | 09:12 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Brake adjustment on the rear arm or relocate the rear arm on brake to get more tenion on lever should fix that problem!!!I missed the model type But if an clutch on left side then adjust clutch cable at engine case to get the correct freeplay!!!
Old Dec 29, 2011 | 10:19 PM
vangasman's Avatar
Yeah, thats for the rear brake. If you can't get enough adjustment out of it the cable may be stretched because thats also the parking brake.
Old Jan 13, 2012 | 11:41 AM
stitchit1's Avatar
Update: fInally picked up the Yamaha Manual. Now where to start.
I'm looking at the carberator first, but I'm wondering: of it had a carb kit late 2010, would I make any progress by simply "Cleanibg" it? If so, with?
Old Jan 13, 2012 | 03:27 PM
EPI Shawn's Avatar
yeah just cleaning the carb will most likely do the job new bowl gasket if needed check the needle and seat to while you are in there run a twisty tie through the jets ( strip off the plastic covering) brake cleaner usually works good and compressed air blow brake cleaner through every single passage in the carb then blow out with compressed air then put it back together and take it for a rip set the air/fuel screw to bout 2 1/4 turns out.
Old Jan 13, 2012 | 07:15 PM
stitchit1's Avatar
Thanks! I'll give it a shot!
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
