jetting for warrior
Old Mar 16, 2001 | 05:03 PM
Wicked98Warrior's Avatar
i just got a pro circuit t4 slip on for my 98 warrior. i have a pro flow clamp on filter, will be running no airbox lid, and am at 400ft elevation...what should my main jet, pilot jet, and needle clip position etc. be if neede to change? thanks!
modified 98 warrior
Old Mar 16, 2001 | 06:02 PM
hot_shoe_cv's Avatar
There's no question that you need to rejet big time. At your sea level elev. you need to goto at least a 157 main jet for a test ride/plug read. You may find after reading your (new) plug that a 157.5 is called for. I would leave the jet needle in the nominal position #3. Always jet for 3/4 to full throttle, which is the main jet before changing anything else. Then when that is finished you can check performance in the other circuits. I'd be quite sure your needle jet will be okay at stock.
Old Mar 17, 2001 | 02:35 PM
all right thanks....any onther input out there??
-moddified 98 warrior
Old Mar 18, 2001 | 01:03 AM
1BadWarrior's Avatar
I have a 99 Warrior with a White Brothers E-Series with 7 discs on it, K&N air filer and 4 one inch holes in the lid. I live at about 1400ft and I have a 150 main jet, 45 pilot jet and I think the clip is either 3rd or 4th. I think it is the 4th position. My Warrior runs great.
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
