BLASTER ENGINE SWAP?? HELP
Old Mar 16, 2001 | 09:07 PM
01MXBLASTER's Avatar
WHAT IS THE EASYEST ENGINE TO PUT IN A BLASTER, BUT NOT SLOWER THAN A BLASTER
Old Mar 17, 2001 | 03:52 AM
Screamin96's Avatar
Um, whatever you can get to fit i guess. [img]i/expressions/face-icon-small-smile.gif[/img] No engine is gonna be "easy" to put in.
Hey check out https://atvconnection.com/ the best site on the net for ATV information.
Old Mar 17, 2001 | 08:48 AM
AirBanshee01's Avatar
The Blaster frame is small to begin with. You are probably not going to have much luck with that.
Try a Badger motor!!!!!!!!
Old Mar 17, 2001 | 05:26 PM
bermbanger's Avatar
a blaster is a small engine. try the skyhawk 150. it would suck really bad tho
Old Mar 17, 2001 | 07:24 PM
BiffBlaster's Avatar
I wouldnt recommend swapping another motor into a blaster, the frame is too weak to handle the kind of power from bigger motors, and you would most likely need all new motor mounts welded in. although on Macdizzy's website he has someone who put a 88' YZ250 motor in a blaster and it turned out ok.
http://www.macdizzy.com/yfsyz.htm
Old Mar 17, 2001 | 09:58 PM
brokemybanshee's Avatar
I'd say that possibly the easiest would be a Tri-z motor?
bzdok1234
30
Feb 23, 2016 01:55 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
