warrior tie rods
Old Apr 11, 2012 | 08:53 AM
jloconti90's Avatar
Default warrior tie rods
are the left and right tie rods the same? is there a special way to allign the front end after replacing the tie rods?
Old Apr 12, 2012 | 09:21 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
I can't remember if the tie rods are the same or different. I think they are the same.
As far as alignment, I have never found a quick, easy way. I'm not going to describe this well but, I've always did my best to find a center point on the tires and measure front and back center points of the tire to get the toe angle right.
For alignment I used the back tires and long straight edge to make a straight line the length of the quad on both sides. you can measure out from the tires a few inches and get your lines outside the quads front tires. Measure from your line to the front of your tires on both sides to get the alignment.
It takes a little trial and error but, it seems to work best for me.
exmotocrosser
Sep 13, 2019 06:12 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
