86 moto 4 fuel problem
Old May 26, 2012 | 07:07 PM
Devlin stutts's Avatar
Default 86 moto 4 fuel problem
I just bought an 86 moto4 250. When i turn the fuel switch to on or to reserve it pours fuel out the carburetor drain tube????? why does it do this????
Old May 26, 2012 | 07:16 PM
Jaster94's Avatar
the float bowl drain? i'd say the screw is open or some debris is in it keeping it from sealing the drain. if you're talking about a different tube than what i'm thinking of, the float/needle valve could be stuck open.
Old May 26, 2012 | 07:33 PM
i believe it is the float bowl drain, how can i fix it
Old May 26, 2012 | 09:51 PM
Jaster94's Avatar
bottom of the float bowl, where the hose connects, is there a "screw"? if so, unscrew it a ways, let the gasoline flow, then retighten it. there may be debris in the seat of the screw. if that doesn't do it, isolate the fuel tank from the carb, take the carb off or just remove the float bowl. if i was you, seeing how it sounds like this quad has sat for a while, go ahead and remove the carb and give it a good cleaning. jets also, then we can get all of the debris, solids, and varnish gunk out of the carb. in case you don't know how to clean a carb or its jets, here's a hyperlink or two to help guide you.
how to clean a carb on a ATV - YouTube
How to clean a carburetor in 15 minutes - YouTube
your carb may not be identical, but it's the principle of the exercise. all carbs have to be cleaned sooner or later and most are done the same way.
skinnyr6
Aug 25, 2023 02:18 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
