Yamaha Terrapro stalls engaging PTO
Old Jun 30, 2012 | 11:10 AM
Rayroc's Avatar
The deadline for Fire Department brush clearing is supposed to be today... Which means I better get my butt back to the ranch and solve this problem once and for all. Man I've got a lot of work to do and don't wanna be having to use weed eaters for a week. With the Terrapro I can get it all done in less than a day
With all the fires going on in Colorado, I'm sure the Fire Dept. won't be cutting any slack.
I finally got the repair manual so hopefully that will help.
Will let you know how it goes.
Old Jun 30, 2012 | 12:33 PM
95wolv's Avatar
Good luck man !!, my brother just got back into his house in Colorado Springs, houses burned less than 4 miles from him, so I send you the best of luck in your battle out there !!
Old Aug 13, 2013 | 10:43 AM
HunterBob56's Avatar
Can you tell me what you found out on your pto problem on your terrapro. I am having the same issue with mine and can't figure it out. Any help would be appreciated. Thanks
Old Feb 23, 2014 | 09:46 PM
The.Kid's Avatar
Originally Posted by Rayroc
That's a smart lead to follow.. Gosh, I didn't think of that and it makes a lot of sense.
I removed the seat and air filter chamber, and the only thing the pto lever does is pull a spring tensioned cable which lowers down the idle pulley into the tension of the driving belts. That is how the pto gear shaft gets rolling. As far as I could see I couldn't find any switch connected to the pto lever or cable. We do know that when put in high gear, the engine will stall if the pto is engaged. I'll look at the Low/High gear lever for the disconnect switch that may be the culprit. Thanks 95wolv
Five more days and I can't wait to get back to the ranch!
This is an old thread but the solution was never stated. The gear selector need to be in Low gear. Slow speed, high rpms. Next if the engine dies engaging the governor level means the implement switch at the left rear attachment point is defective in some way. May sure your in first or second gear as well.
Old Jun 27, 2017 | 12:20 AM
  #15
BlancDeBlanc's Avatar
Default Governor Stalls Engine, Terrapro
Hi The.Kid,
I'm not sure if you're still checking these threads. I've got a 1988 Yamaha Terrapro with the symptoms you described above. Sometimes when I try to engage the governor lever it stalls the engine. You suggested the problem is probably the rear left hitch safety switch. I don't think I can buy a new one. How do you suggest I bypass the implement switch? Should I just cut it off and splice the two wires together? I hope this message reaches you safely. Thanks!
BlancDeBlanc
Old May 25, 2018 | 09:38 AM
  #16
Bryan Beha's Avatar
I rewired the switch to a toggle up near the handle bars. If I want to go in high gear I flip the switch. Also makes a great kill switch when using the pto. Thanks
Old Jun 8, 2018 | 08:45 AM
  #17
Clovej's Avatar
Default Terrapro stalling
Originally Posted by mginwyo
just wondering if you found out anything on the stall problem. You've got me curious and its a tough deal since I don't have a cat!
Have same problem wondering if you could tell me where wire is so can do same to my terrapro sounds like good deal having kill switch thanks
Old Jun 8, 2018 | 12:03 PM
  #18
Bryan Beha's Avatar
clove search on FB Terrapro. I made a page with the wiring diagram
Old Jun 8, 2018 | 01:47 PM
  #19
Bryan Beha's Avatar
Old Jun 8, 2018 | 09:45 PM
  #20
Bryan Beha's Avatar
If you still can’t find it let me know.
cdoren
Aug 16, 2015 11:22 PM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
fire1998
Aug 6, 2015 02:46 AM
fire1998
Aug 4, 2015 08:54 PM
ghost civic
Jul 15, 2015 10:48 PM
