New owner of 350. First mod?
#44
I suggest a hmf or fmf pipe it will give you a little more power. another easy mod is if you like to have high torque so u accelerate faster get a bigger front sprocket or if you like faster top speed get a bigger sprocket in back.
#45
You have it backwards
#47
So what jet system do I need? Dynojet? I don't think FMF jet system makes a set for the Raptor 350. I'm planning on putting a K&N filter without the box. I believe I need to jet the carb correct?
When looking at the manual online there seem to be 3 jets on the carb. The one I noticed has 22.5 jet in it. Is that the one I'm suppose to change? If so, what's the next jetting up from there? Very new and still trying to understand.
#48
Dynojet is a good jet kit. It comes with instructions on which jets to install. You will need to rejet if you run an aftermarket filter and no lid/box.
My vote for a pipe would be the factory headpipe with a slip-on HMF muffler. The factory headpipe is oversized from the factory, so an aftermarket headpipe would not give any performance increase.
#50
Are theses the pilot jets that I need? Or are these factory ones?
