Warrior won't go into gear
Old Mar 18, 2013 | 04:37 PM
Warriordude88's Avatar
Default Warrior won't go into gear
Hopefully someone can help me, I bought a 2003 warrior. When I got it home I could shift it into gear and wanted to try to pop start it the next day( I bought in need of a starter clutch so the starter just spins and engine doesn't turn) when I went to pop start it I couldn't get it into gear?? I tried and tried played with reveres a little, still got nothing. I was messing with the reverse prior to pop starting it as well. What could cause this, the guy sold it to me saying he put a new clutch on, when I pull the clutch lever in its a little on the heavy side isthis normal? Did he screw up? Where do I start? Any help at all would be awesome
Old Mar 25, 2013 | 10:01 AM
SpyderV8's Avatar
Mine has done this to me also, it can get In between rev and forward on the direction gear selector. Try rolling it (use of a buddy will help) and pushing down on foot gear selector and pull up on **** for direction selector (the rev lever) and pushing it forward, all while rolling it hopefully the gears will mesh back in together and it'll be in a forward gear. Without the engine or tranny turning the forks in tranny can't push past a gear that's not meshing with the next, make sense? Give a try and post. A heavy clutch could be normal if stiffer springs were installed, or maybe cable needs some oil.
Old Apr 8, 2013 | 11:26 PM
dakbee's Avatar
does the warrior have a linkage setup for forward/reverse selection? if so try adjusting the linkage, it may not be putting it into forward all the way
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
