YFM200 cam chain adjustment
Old Jun 4, 2013 | 08:01 AM
bvolks's Avatar
Default YFM200 cam chain adjustment
How do you adjust the camshaft chain on a 1985 YFM200? I took a guess at how tight to set it when I rebuilt the motor on my brother's bike last year but it's time for an adjustment and I want to be sure I do it right this time.
Old Aug 26, 2013 | 04:18 PM
bvolks's Avatar
Anyone?
Old Aug 26, 2013 | 07:16 PM
Bigbear_88's Avatar
Look on the left side on the back of the engine beside the carb there will be a oval lookin piece that has 2 bolts holding it on and 1 10mm bolt directly in the middle of the piece. Pull the middle bolt out use a small flat head screw driver and turn it counter clock wise. You don't wont to force it tight just snugg it up.
Old Aug 26, 2013 | 07:50 PM
bvolks's Avatar
Thanks. That's pretty much how I did it when I rebuilt the top end of the motor over a year ago. I'm getting ready to adjust it again and wanted to make sure I'm doing it right.
Old Aug 27, 2013 | 10:40 AM
bvolks's Avatar
I just finished adjusting it and it was really slack. It sounds much better now but the tensioner is nearly maxed out so I assume a new chain and/ or guides will be in it's future.
Firefighter400
Oct 8, 2022 06:38 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
