1988 moto 4
Old Oct 3, 2013 | 12:13 AM
Zaffle21's Avatar
Default 1988 moto 4
Just bought this bike it has 2 handles does it have a clutch thought it was automatic also where could I find a starter and a gasket for it started is gone and was leaking oil due to bad gasket thanks for any help or things I need to look for
Old Oct 3, 2013 | 10:02 AM
Steven Bandemer's Avatar
2 handles could just be the brakes. I have had some that one will control:
rear brakes and front brake
Front brake
Foot pedal is rear brake
So that does not mean it has a clutch if you are really unsure follow the cable and see where they go. If one is going into the motor caseing its a clutch otherwise they are most likely going to the brakes.
I am not familiar with that model so only responded because no one else has
Old Oct 3, 2013 | 10:24 AM
TLC's Avatar
TLC
I had one years back 250 moto4 1987. There is no had clutch. One leaver is back and the other is front.
Mind even had a Low Range,handle by motor.
I like these guys for parts. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
You mean you have no starter like in its missing or it just does not work?
Much cheaper to just rebuild it with a starter kit.
Old Oct 3, 2013 | 01:48 PM
Raptor450's Avatar
It does have a clutch, it's called an automatic clutch. When you pull up the gear shift lever with your foot, that automatically disengages the clutch. There is no clutch lever on the handlebars. All the levers on the handlebars would be brakes. Right lever would be front brakes, left lever would be rear brakes.
Old Oct 3, 2013 | 09:27 PM
Zaffle21's Avatar
Thanks for the help guys was taking the side cover off seen a clutch and seen the 2 cables went to the front brakes does anyone know how much oil I need to put back in when I refill it
Old Oct 4, 2013 | 08:49 AM
TLC's Avatar
TLC
Its a 250? About two quarts maybe a little less. Yes two cables to the rear drum by back wheel. One is the hand leaver the other is the foot brake. The wing nuts adjust the brake shoes.
Old Oct 4, 2013 | 08:54 AM
Zaffle21's Avatar
Thanks again it just had me confused for a min cause my other bike has a clutch front brake handles then rear is just the foot thanks again for all the help
wendal
Aug 3, 2024 10:03 PM
Valder
Nov 28, 2020 07:38 AM
fredrikrosen
Oct 29, 2016 07:56 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
