warrior starting problem
Old Nov 17, 2013 | 09:04 PM
Dave Ems's Avatar
Default warrior starting problem
hey guys new to this and need some help i have a 97 yamaha warrior and i cant get it to turn over im getting power threw the brown wires at the front of the quad if i un plug the brown wire from the reverse light and touch it to the frame it sparks but if i take the buld side and touch the frame it turns over but the lights are dim any answers pls
Old Nov 21, 2013 | 08:39 PM
Raptor450's Avatar
Tracking down electrical problems can be a nightmare, especially over a forum lol! I'm not real familiar with a Warrior's wiring, so we'll have to take it 1 step at a time. I'm not sure what a "buld side" is, but if the lights are dim, it could be several things like a bad ground, or the voltage regulator is not working correctly. The Warriors were also bad about wires rubbing the frame where they loop over the frame in the rear under the rear left fender. Make sure there are no bare wires touching anything metal.
Old Nov 26, 2013 | 11:13 AM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Warriors are notorious for having ground issues. Usually the issue is in the kill switch area... but have been in other places. This was passed to me many moons ago in this list and it fixed my issues. I replaced the switch. Also, if the machine has been in water or mud a lot, then you may need to start a tedious process of looking at all your wiring.
If you are friends with an old Yamaha mechanic, you may try picking his brain. Or search the old threads. It would have been 7 or 8 years ago. Not sure if there is a search mechanism that goes back that far. This new Software is way different than the original list server software, and it was before they sold out to current owners.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
