big bear no spark
Old Nov 21, 2013 | 05:43 AM
abadbowtie's Avatar
Default big bear no spark
I am working on a 98 Yamaha big bear that will not start it ran fine then sat for a month or so know will not start. I pulled plug and it looked really old so I did replace it first. If I ground the plug against the head and crank it will spark once or twice in about 20 minutes of playing with it. The rest of the time no spark. I even pulled the pink wire going into the coil and checked for power while cranking and nothing. So I pulled all front plastic last night and am not really seeing anything that screams rubbed or chewed wire. Please point me in the right direction on were to check the other end of the pink coil wire for power at source. I also see there is a black on the coil assuming it is just a ground. Thanks in advance
Old Nov 23, 2013 | 06:11 PM
spits's Avatar
The sparkplug cap could be bad. If it is a bakelite (hard plastic) it will have a diode that could be bad, or you could have a c.d.i. that has gone bad. Also it could be coil a coil.
Old Nov 24, 2013 | 10:58 AM
TLC's Avatar
TLC
Try this , its a 350 Warrior but its the same 348cc motor as your Big Bear.
Old Nov 25, 2013 | 11:17 AM
abadbowtie's Avatar
Well I have messed with it a little more and seem like I get more spark more often but sure does seem week I am thinking maybe start with a new coil since it could be week. Is there a good way to test with another power source straight to it or something to see if it runs then.
Old Dec 21, 2017 | 07:10 PM
stencell's Avatar
Redseal Tech
Have you fixed your problem?
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
