Yamaha bruin 350 electrical problem
Old Jan 14, 2014 | 08:52 AM
WhitewolfCC's Avatar
Well I'm thinking it is the solenoid because I can't get a reading on the back of the solenoid where the 3 wires plug into I only get a reading on the front of it where the battery cable bolts on. Would the honda place be able to test it if I took the solenoid up there? I don't want to take the whole bike up there
Old Jan 14, 2014 | 11:04 AM
michaelh6's Avatar
on my 04 bruin i can sometimes get the lights to come on but as soon as i push the start button it clicks and everything goes out then it takes 5 mins. to get the lights back on. they start real dim then slowly get brighter
Old Jan 14, 2014 | 01:27 PM
I have no lights or click. Gonna work on it more today and see if I can find the problem.
Old Feb 26, 2014 | 03:31 PM
Metalbone Ranch's Avatar
I am having this same issue. Did anyone figure out what is causing it?
Old Feb 26, 2014 | 05:30 PM
  #15
One of the 4 prongs on the back of the solenoid had broken off and got stuck in the plug. I ended up trading the bruin off so I'm not 100% certain that's all it was but I'm pretty sure
Old Feb 26, 2014 | 05:52 PM
  #16
quadsr4me's Avatar
Have you checked the fuses?
Old Feb 27, 2014 | 02:44 AM
  #17
On most Yamahas and Suzukis the positive pickup wire for everything except the starter goes through a fuse on the solenoid, then to the regulator and ignition switch. If anything goes wrong between the solenoid and the regulator, the engine won’t start on the button, nor the lights work but, once running, power from the regulator is working the lights etc. It is usually the solenoid fuse, but can be the solenoid or the wire from fuse to regulator. A bad earth from battery to engine or frame can also give this problem. Test everything with a test lamp, not a multimeter.
Old Feb 27, 2014 | 05:56 AM
  #18
Dammar's Avatar
my 04 bruin 350 had a plugin up front that connected 6 grounds together one of them was corroded and almost burnt looking the problem i had was not much spark fixing this did not cure my problem but did help some might be worth checking
Old Feb 28, 2014 | 11:15 PM
  #19
The.Kid's Avatar
Sounds like you have a safety switch failure preventing it from starting. Working with a diagram would be helpful. Easy to get lost in the harness without a schematic.
Old Aug 26, 2021 | 08:27 PM
  #20
dcm88's Avatar
wiring diagram hope it helps
