Launching Boat With Atv?
Old Jan 12, 2014 | 09:59 PM
wildfan97's Avatar
Default Launching Boat With Atv?
So i have a 16ft alunium boat (unsure on weight) and was wondering if it could be launched by an atv? If not could you use an atv and a winch? It would be on a concrete ramp and the trailer toung weight is around 100 lbs. By the way if i was going to try and do this, i would attach a tow strap or rope to a tree just long enough so the atv could not go in the water.
Old Jan 13, 2014 | 09:14 AM
TLC's Avatar
TLC
With a ATV you can skip the boat ramp and do it on a beach.
We back up our 14ft boat with a 90 outboard into the water all the time.
By the time the ATV is in seat height of water the boat has floated of the trailer long before.
ATVs can easily pull big boats. This is a 500 Scrambler without even a low range.
ATV's in general have a tow rating of 1,100lbs to 1,200lbs which can be pushed a lot further for short periods.
Old Jan 13, 2014 | 12:31 PM
Only thing I can think of with the size boat you'd be launching is to watch out for a super steep boat ramp. Quads can be tippy front to back if the slope is steep enough. Put a couple hundred lbs. of pressure on the hitch and it can make it worse. Other than that, make sure it has a good parking brake.
Old Jan 13, 2014 | 08:49 PM
wildfan97's Avatar
Okay thanks! I have an 16ft aluminum outboard 70, estimate weight is 500-700 lbs and like i said toung weight is less than 100lbs. My yamaha wolverine 450 4x4 pulls it in the yard easily so i will just tie up to my other wolvey incase anything goes wrong.
Old Jan 14, 2014 | 08:23 AM
Oldbear's Avatar
Install a snorkel kit just in case.
Old Jan 14, 2014 | 11:59 AM
hahahahaaa... Love it.
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
carid
Sep 14, 2015 03:40 PM
black_thunder
Aug 19, 2015 03:23 AM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
