Removing the baffles?
Old Feb 22, 2014 | 12:33 AM
2003wolverine350's Avatar
Default Removing the baffles?
So I have a wolverine and I removed the baffles and I was just wondering if this will mess my bike up? As of now it is NOT running lean. But will it cause engine trouble?
Old Feb 22, 2014 | 04:23 PM
Okay so I put my baffle back in and WOW! The throttle is so much more crisp I definitely recommended NOT to take the baffles out!
Old Feb 27, 2014 | 01:36 PM
steven_james's Avatar
It changes the back pressure on the engine and can/will affect its performance
Old Mar 2, 2014 | 06:12 PM
gangle04's Avatar
Default lean
id say when u cut out your baffles you were running lean without knowing it, 4 stroke motors need very little back pressure , if you took out your baffles, removed your airbox lid and went up a jet or 2 on your main you'd probably actually notice a power increase, the reason back pressure is needed is on every exhaust stroke the last push of exhaust will actually help pull the next chamber full of exhaust out, this is why you get you power band in 2 strokes, its the right rpm where the exhaust helps pull all the exhaust out to make room for the maximum amount of fuel/oxygen to enter the chamber on the next stroke. on 4 stroke motors especially singles, back pressure does very little because there is an exhaust stroke (exhaust valve open, piston going up) expelling pretty much all of the exhaust, then an intake stroke(intake valve open, piston going down) sucking in fresh air/fuel only from intake......hope i explained this well enough without getting to far into detail.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Bigtwin700
Sep 9, 2015 09:32 AM
