2000 ds650 timing chain problem..
Old Mar 5, 2014 | 09:15 PM
julio Cantu's Avatar
Default 2000 ds650 timing chain problem..
hi everyone.. a mechanic told me my timing chain could of been loose cause when i gave the bike throttle it would spit the gas out through the carb instead of exhaust so i opened up the top and my chain was a little loose so i loosened the tensioner screw and pushed it back it and my chain got tight but i heard you have to line up the indents on the sprokets to the edge of the casing but i dont know how to turn the sprokets or rotate them ?? any help would be glady apprecitated..
Old Mar 9, 2014 | 06:25 PM
infantryvet's Avatar
your timing is off a tooth.excessive chain slack from wear and tear.the tensioner only takes up but so much slack until the chain stretches more.there a cover on the throttle side on bottom of motor that will acess the flywheel to turn engine over with wrench.had a couple ds650s over the yrs got good working on them.been awhile though lol
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Sjrpp
Jul 5, 2015 09:04 PM
Mikea1978
Jul 4, 2015 12:37 PM
