timberwolf loose axle
Old Apr 30, 2014 | 07:50 PM
mrbonami2's Avatar
Default timberwolf loose axle
Hello
My timberwolf 250 the rear axle spline is loose a bit i mean i go forward it make tock and go backward tock... Some loose..
Any idea if i can add grease to make it last for long?
or loctite ? Duct tape each week?
it 358$ a new gear and the axle is idk how much...
Old May 1, 2014 | 11:01 PM
mrbonami2's Avatar
Helppp
Old May 3, 2014 | 07:27 AM
The axle shaft is often a lot more worn than the crown wheel as the axle is softer steel. If the crown wheel is not too bad but the shaft is nearly shot, it may be best to get a new shaft before any more damage is done to the crown wheel. If they are both nearly gone I use a hard grease, but they won't last long. Make sure the nuts that hold the shaft in place are tight, it is these coming loose that does the damage, though Honda 420 axles can come loose with the nuts mad tight and Loctited.
Old May 3, 2014 | 12:37 PM
mrbonami2's Avatar
a bearing was shot and before i see it there where damage to the spline so yea i will look if the crown is good
Thank you
An axle is 200$ +
i looked at locktite liquid metal 660 but it not made for that...
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
bmark0610
Sep 7, 2015 09:42 PM
