Blaster problems??????
Old Apr 4, 2001 | 11:07 PM
brokemybanshee's Avatar
Ok, thats half of it (top of the carb), Im going to try to explain this as easily as possible.. Take your front hood off, follow the wires from the throttle to a little box, there are 2, make sure you have the right one. Un-plug it and this will make the system activate and you will not be able to touch the throttle without it bogging. (try it out, that should tell you if it is the problem) To totally disconnect it you have to unplug the box AND the wires coming from the carb.
Old Apr 4, 2001 | 11:11 PM
Forgot to mention, if you do disconnect it just leave it on there, it wont harm anything, if you take the carb top off you'll need a diffrent one or you'll have an airleak which is BAD..
Old Apr 4, 2001 | 11:24 PM
Dano2000's Avatar
YEEEEEEEEEEEEEEEEEEEEEHAAAAAAAAAAAAAAAAAAA!!!!!!!! !!Hey thanx a million that worked i just got back from a test spin and it works like it did before you are all fantastic!!!!!!!!!!!!!!!!!!!!!!!!
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
