grizzly owners
Old Apr 17, 2001 | 01:27 PM
grizzzzzz's Avatar
if 3 out of 4 say yamalube is better why would you want change. if it isn't broke don't fix it
Old Apr 17, 2001 | 02:43 PM
Mudrush's Avatar
I like sythetic oil myself. even though it's supposed to last twice as long as petro based oils i still change it two or more times a year.
I am sure that the temp range is definately better than regular oil. and i know that i have a 88 chevy truck with over 260,000 on it and it has had syntec in it since about 40,000 miles. My Grizz definately seems to run cooler with synthetic. Due to the decrease in friction that comes with synthetics. i ran mobile 1 v-twin for a while and changed over to syntec since then. but compared to petro oils it is a lot cleaner when i change it than with yamalube. The factory tries to give a good oil that will work adequately in as wide a range as possible and at a good price. I have seen how thick oils gets when its very cold and have used synthetic in very cold weather and it is definately much easier to pore in cold weather. the high end temp. where sythetics break down is about 150 degrees higher on synthetics than petro based. I am convinced that sythetic is better that regular oils. You just need to make sure that you get synthetic non friction modified oil for use on wet clutches. Just my $0.02 worth.
Old Apr 17, 2001 | 10:20 PM
GRIZZZZZZZ's Avatar
but i thought the grizz doesnt have a wet clutch, so i shouldnt matter right?
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
Ahtatu
Sep 28, 2015 12:14 PM
cboler9
Sep 24, 2015 08:35 PM
