2000 blaster
Old May 4, 2016 | 12:18 PM
Bill Cutler's Avatar
Default 2000 blaster
Got a 2000 blaster. When I got it it didn't have an air filter. It would start but the idle would scream. I put an air filter on it and it will not start at all now. Any ideas?
Old May 4, 2016 | 01:00 PM
Fasteratv's Avatar
If it was ran without an air filter, I would do a compression test before doing anything else.
Old May 20, 2016 | 06:02 PM
davidbrennan5's Avatar
It will run if it has : 1. (fuel) check plug and see if it is wet 2. (spark) get a inline spark tester and kick the bike over and see if it lights up 3. (compression) kick it over slowly does it build good pressure? when I buy a bike I usually drain the fuel clean the carb and change the plug. I change the fuel line if it looks like it needs it. If I had to guess I would say your carb is gummed up.
Gusgusa1
Jul 24, 2016 01:09 PM
cohunter
May 13, 2016 01:49 PM
Ean
May 8, 2016 07:42 AM
1papasmurf
May 1, 2016 01:39 AM
jacob9933
Apr 29, 2016 04:46 PM
