worrior hitting rev limiter
Old Jun 27, 2016 | 08:39 AM
barge bait's Avatar
Default worrior hitting rev limiter
I jus picked up a 95 worrier 350. It had no spark at first. put a stator in it fires right up. Go to throttle up and it hits the rev limiter. Ihave read there are several safety switchs on this machine. brake netural rev. does anyone know how to disable all of them so I can get this thing to run. Or should I be looking towards the cdi part of the system. Any help would be wonderful. Thanks for looking Dave
Old Jun 27, 2016 | 11:33 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Try to disconnect the left handle clutch and brake switch an see if this will help you most of the time its the brake switch when it sticks the cdi thinks the parking brake is on an this caused the rev limiter to come on.
Old Jun 27, 2016 | 03:25 PM
barge bait's Avatar
Thanks for the reply I will try that first. Another thing is its doing it in neutral I'm going to try it in gear tonght
Old Jun 27, 2016 | 04:31 PM
Loved
Community Favorite
Yes if the switch is bad the cdi thinks parking brake is on an this will may the rev limiter enanage even if in neutral good Luck
Old Jun 27, 2016 | 05:07 PM
ag2560's Avatar
If it`s a 95 it won`t have the E-Brake switch that started in 97 on up. When you say it hits the rev limiter is it breaking up at high RPM or not revving up at all?
Old Jun 27, 2016 | 08:38 PM
barge bait's Avatar
It has an e brake plate on the caliper. Yes it starts and idles great just over half throttle rpm starts breaking up. Switched out cdi New stator. Switched coil. Plugged the 2 wires off the clutch together. Checked valve Clarence. I am mechanically inclined but this thing is killing me. Also checked all grounds. Don't know what to check next
Old Jun 28, 2016 | 04:33 AM
ag2560's Avatar
It could be carb related hows the spark plug look?
Old Jun 28, 2016 | 05:32 AM
barge bait's Avatar
I hit it with starting fluid when the rpm start to break up no change
Old Jun 28, 2016 | 08:56 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
My son had a Raptor that did that. It was the reverse light wire had rubbed thru causing the CDI to think it was in reverse . Try it in gear also, may be tied to the netural light.
tecate1987
Jun 1, 2016 10:01 PM
Thalowin
May 19, 2016 09:45 AM
lucman
May 16, 2016 05:02 AM
DEREKOLDHAM
Ask the Editor
May 15, 2016 05:44 PM
