Carb is overflowing
Old Aug 13, 2017 | 06:46 PM
SharpTJ's Avatar
Default Carb is overflowing
Gas continues to drip from the overflows. I have replaced the needle valves and seats with OEM and the floats are at 13mm using a clear tube.
What else could it be? It only drips at idle best i can tell.
Yamaha Raptor 660
Old Aug 14, 2017 | 02:43 AM
" It only drips at idle best i can tell."
Usually they only drip when engine is stopped. If it doesn't drip then, maybe your idle is a bit "lumpy" making the carb bounce around. Could try speeding it up slightly via the throttle stop screw.
