Oil leak in drive shaft boot on my 350 wolverine
Old Aug 21, 2017 | 07:13 PM
Mantschman's Avatar
Default Oil leak in drive shaft boot on my 350 wolverine
Any insight on this woul be extremely appreciated
Old Aug 23, 2017 | 02:36 AM
I haven't done much with the Wolverene, but if it has a manual shift "Big Bear" engine, and it is engine oil in the boot, the angle drive oil seal will have gone. You have to remove the swinging arm assembly, then the angle drive box on the side of the engine, then strip the angle drive, to get at the seal.
Old Aug 23, 2017 | 12:28 PM
Mantschman's Avatar
Default Ouch!
Thank you for the info! Was hoping little less tearing apart!
Old Aug 28, 2017 | 02:51 PM
NCLandBroker's Avatar
Common problem on these machines. Had to fix mine a couple years ago. You do have to remove the swingarm and the angle drive, as noted.
Old Aug 28, 2017 | 05:37 PM
Mantschman's Avatar
Default Thanks!
Thanks for the info. I guess i know what i have to do,unfortunately! Thanks againd
