LED light install on 01 beartracker
Old Sep 14, 2017 | 01:41 PM
Tim Osness's Avatar
Default LED light install on 01 beartracker
I just purchased 2 4inch 18 watt led light cubes. Was wondering if anyone knows how to wire them up on a beartracker. I want them ran through the hight beam switch, so they come on when i flip the high beams on.im not that great at wiring. Any help will be appriciated.
Old Sep 15, 2017 | 02:25 AM
Positive wire from LEDs should be connected to a wire behind the headlamp, not certain, but I think it is yellow, best to check if this is live when headlamps are on full beam. A scotchblock connector can be used, but they don't like water, so somewhere dry if possible, and wrap it well with insulation tape. The negative wire from LEDs should go to earth. If there isn't a good earthing place in the headlamp shell, I often use a round "binding post" type crimp on connector fitted under the head of a rack mounting bolt. Clean any rust off to make sure you get a good connection. You may need to go a size up on the main fuse, but try it "as is" first.
