Wont run above idle.
Old Sep 27, 2017 | 08:49 PM
Leraythe4th's Avatar
Default Wont run above idle.
I have a warrior that won't run above idle. Meaning as soon as you hit the gas it dies. Has a brand new carb on it but it acts the same w/either carbs on it. It has good spark when tested with bike not running. The compression is higher than i have ever seen, around 200 lbs. Timing is set right, so i thought with high compression we needed high octane gas but aviation gas would not fire it. Running out of ideas. Anyone have any.
Wolfdog2314
Apr 20, 2020 02:15 PM
Richvoss
Sep 25, 2017 07:52 PM
Elliott000
Sep 22, 2017 04:01 AM
townhound
Sep 17, 2017 10:11 AM
Birddogk
Sep 13, 2017 02:55 PM
