Wolverine clickey tickey click
I ve had a click tick noise just like a bad u joint would sound. I ve had it apart completely, everything is in good shape or tight. U joint is fine, axle splines ok, swingarm bearings where fine but I greased them. The diff seams to be smooth and has no exssesive play. Maybe under a load the diff could be the culprit? Any info or ideas ? Thanx
Are you sure it is the rear as, depending on year, UJs and CV joints in the front are more likely to clack. If it is at the rear, all I can think of is a chipped tooth on the crownwheel or pinion, or something catching in the rear brake.
